• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Developer
    New Member
    Autodesk Infrastructure Map Server 2012 on 64 bit
    1113 Views, 2 Replies
    05-08-2012 03:40 AM
    Hi everyone,
    I am trying to run Autodesk Infrastructure Map Server 2012 on 64 bit Windows 7. Everything installs perfectly without any error , but when i try to login on administration login page with the default user "Administrator" , & password "admin" ..it says wrong password. same issue from the Studio, it is not allowing me to login ... same with the mapagent ...the main page appears but when I give credentials it simply gives an error. I reinstalled, checked all the logs, congif's ..still can't pinpoint what's going on.
    I am using the bundleded installer of the trial with java as the development language. It has configured java before install, confirmed it a number of times, tomcat working fine ...anyone have any idea where & how I can troubleshoot further? I have attached the exact errors.
    Thanks in advance,
    Atika
    Please use plain text.
    New Member
    Re: Autodesk Infrastructure Map Server 2012 on 64 bit
    07-02-2012 08:30 AM in reply to: IAtika
    Hello, I just installed IMS 2012 and have similar problem trying to connect to Site Administrator. Did you have it resolved? I would really uppreciate the assistance. v/r, Larisa
    07-08-2012 08:00 PM in reply to: IAtika
    Have you tried restarting the Apache Web Server?
    - Jackie
