• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Developer
    Valued Contributor
    Anybody know watermark function is working in AIMS2013
    885 Views, 3 Replies
    09-14-2012 12:34 PM
    I try to add a watermark to my map using AIMS2013, but is does not work. It should be straightforward to use studio to do the work, some reason, it doesn't work.Anybody tried? Any suggestion? By the way, I using flexible layout and all the layers I added into base layer group.
    Please use plain text.
    wilsonherrera
    Re: Anybody know watermark function is working in AIMS2013
    10-19-2012 09:50 AM in reply to: swimming123
    did you created a watermark symbol? once you created it, you attached the watermark at the layer or attached the watermark to the map? you should also watch the watermark position, it could be hidden behind another object (like the overview map)
    i have several maps with watermarks and never experienced any kind of troubles.
    also, check the image properties, in size and format.
    Valued Contributor
    10-19-2012 01:29 PM in reply to: wilsonherrera
     In my case, I put all the data in BaseLayerGroup (fusion viewer),  so watermark is not show. If I add a regular layer group with light data, my watremark will show if I do the zoom function, but it still doesn't show at the very beginning when the map just loaded. Thanks for your reply.
    10-21-2012 10:51 PM in reply to: swimming123
    To my knowledge, watermarks aren't rendered for tiled base layers. So if your Map Definition has watermarks but no dynamic layers (ie. All layers are base layers), Fusion won't create the necessary OL sub-layer that renders out the dynamic layers, where watermarks will be composited into the overlay image.
    Suggested workaround: Add a blank dynamic layer to your Map Definition
    - Jackie
