• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    workflow for reusing Inventor frame generator models
    388 Views, 3 Replies
    06-17-2011 09:45 AM
    I'm trying to figure out an efficient way to reuse frame generator models. I'm regularly creating multiple versions of a simple steel framed cart for touring stage shows. I've built a frame generator model that I'd like to reuse in multiples for a single project.
    The issue at hand is finding a straightforward work flow to expedidte this process without creating non-unique files all over the place.  Since simply copying or pack-n-go'ing a model doesn't change file names this seems like a likely headache. Doing an iPart type assembly seems complicated, but something I haven't really looked into.
    What I have tried is creating separate Inventor projects for each cart. This seems workable, but very cumbersome with a project that may have a dozen versions of that cart. Switching between project files is a pain. And creating projects within projects doesn't seem to sequester files when working in a higher level project.
    Does anyone have any experience with a similar situation? Thanks for your thoughts!
    Please use plain text.
    *Expert Elite*
    PaulMunford
    Re: workflow for reusing Inventor frame generator models
    06-17-2011 02:21 PM in reply to: jaeckerb
    I think that you've spotted the answer to your own question here!
    The Frame generator is very good for quiclkly Generating frames, but if you need to create a configurable design iAssemblies might be a better answer.
    You could also look into iCopy:
    http://labs.blogs.com/its_alive_in_the_lab/2010/05/icopy-for-inventor-graduates-from-labs.html
    The CAD Setter Out Blog
    @CadSetterOut
    Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
    Active Member
    06-22-2011 04:41 PM in reply to: PaulMunford
    Thanks Paul! I asked around and the iCopy approach was the only suggestion that came up. Sounds like I may have finally found the excuse to learn how the iStuff works. Thanks.
    -Brian
    *Expert Elite*
    Curtis_Waguespack
    06-22-2011 04:53 PM in reply to: jaeckerb
    Hi jaeckerb,
    I have a workflow I use to reuse frame generator frames, but it's not the most straightforward thing in the world, can you give an example or screen shot of how your frame files are typically created and stored now? If so I'll try to post some steps on how to do this.
    I hope this helps.
    Curtis
    http://inventortrenches.blogspot.com/
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
