• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *Pro
    jletcher
    why I rant
    671 Views, 28 Replies
    08-07-2012 01:04 PM
    Here is a prime example of the reason I rant about new interface...
    I know this has nothing to do with the new interface but does it. all the time they screwed with the new interface they could have been fixing this kind of stuff.
    You want a new interface get inventor to work with less bugs oh I know you can't get rid of all the bugs or can you?
    To move forward without fixing the issues you have.
    So if I offend any of the users in the fourms I am sorry but when I am working hard and need to do something and Inventor does not and then a new Interface comes into play but yet the bug that was in the old release is never fixed this is why they want you on subscription so maybe some day in the next 200 releases this bug in 2011 may get fixed.
    OK I'm done.....
    Any one know what pic is here?
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    Please use plain text.
    *Expert Elite*
    Curtis_Waguespack
    Re: why I rant
    08-07-2012 01:11 PM in reply to: jletcher
    Hi  jletcher,
    I suspect your help files did not install correctly due to profiles, permissions, or something of that kind. I don't think what you're seeing is typical of all Inventor installs. I'd suggest posting on the Installation & Licensing forum to see if there is a known issue with help installs for your version:
    http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    *Pro
    jletcher
    Re: why I rant
    08-07-2012 01:21 PM in reply to: Curtis_Waguespack
    This is that local help you had me load in my post about help file.
    I have all permissions when I load Inventor and this was a new CPU well 4 new machines and they all are the same way no virus protection no spyware out of box did all they said to do in the install section.
    Half the help shows a red X or it says cannot display.
    In 2004-2005-2006-2007-2008-2009-2010 I never had this kind of issues this started when they decided to do this wiki help.
    I will post in there..
    Again sorry for rant....
    James Letcher
    *Expert Elite*
    Curtis_Waguespack
    Re: why I rant
    08-07-2012 01:30 PM in reply to: jletcher
    Hi  jletcher,
    Yeah, the fact that the online files weren't working and now the local files aren't either makes me suspect that something is getting blocked.
    I found this link, it's for a different product, but this is the kind of thing that I would think is the issue:
    http://forums.autodesk.com/t5/Installation-Licensing/Civil-3D-2012-not-loading-help-files/m-p/306223...
    I hope this helps.
    Curtis
    *Pro
    jletcher
    Re: why I rant
    08-07-2012 01:42 PM in reply to: Curtis_Waguespack
    Well not sure because so of the things I can't see I can on 2 other machines but not the other and some I can see and they can't.
    I read what they had not sure if I have a day to un-install and re-install but may have too..
    can't get anything done if I can't find the code I need...
    Thanks for the help I know you hate my rants and sorry for them .
    I guess I need to learn not to rant when I get upset.....
    Thanks for the reply..
    James Letcher
    Distinguished Mentor
    Re: why I rant
    08-08-2012 01:00 AM in reply to: jletcher
    Technically I don't think you can still call the interface 'new'.
    The programming help works in 2013, see attached for missing pictures.
    There are a couple of tutorials on mcadForums regarding these VBA functions but you will have to request the old link to be fixed. Regardless you can do most of this much easier now with iLogic.
    Please mark as "Accept as Solution" if it answers your question or "Kudos" if you found it useful.
    Stew, AICP
    Inventor Professional 2013, Autodesk Simulation Multiphysics 2013
    Windows 7 x64 Core i7 32GB Ram FX2000
    *Pro
    jletcher
    Re: why I rant
    08-08-2012 06:20 AM in reply to: Inv_kaos
    Not doing VB or VBA, I am doing ilogic but there are few or no samples of ilogic therre is no section telling you how to get this or this does that for ilogic. I was told most of the API samples are the same as ilogic you just have to change a few things.
    So that is why I was looking at the API or programming help.
    Thanks for the pics and you proved my point in order to get Inventor bugs fixed you must upgrade. This I feel is wrong and not fair to those that cannot afford subscription or a new seat every year as the fix for the bugs.
    James Letcher
    Re: why I rant
    08-08-2012 07:38 AM in reply to: jletcher
    My comments were based on the page that you posted - VBA. This particular help file is only applicable to VBA not iLogic. I agree there should be much more documentation on iLogic. It almost seems like it has been deliberately held back but I think, more likely, it has just fallen through the cracks. There is still significant differences, particularly for new users, between VB.net, VBA and iLogic, that I think could be documented.
    Perhaps Curtis could include a section in Mastering Autodesk Inventor just for iLogic or extend the series to include Mastering iLogic. I am sure spare time is rare but the demand has certainly increased from the early days of iLogic (where IMO documentation was better).
    I think based on the software improvements over the time you have to wait between upgrades that it is more economical to be on subscription. What I disagree on is the initial cost of the software since you never actually own it - only rent it.
    Stew, AICP
    Valued Contributor
    JohnK_TEDCF
    Re: why I rant
    08-08-2012 08:22 AM in reply to: Inv_kaos
    Hey guys! I wanted to let you know that my company offers a video tutorial course on iLogic. We actually have a free iLogic mini-course on our YouTube page if your interested. The mini-course will give you a good introduction to our full course, 'iLogic Made Simple'.
    http://www.youtube.com/user/tedcfpublishing?feature=results_main
    If you have any questions about our courses, feel free to ask!
    John Koop
    Software Engineer/ Inventor Specialist
    TEDCF Publishing
    www.trainingtutorial.com
    Re: why I rant
    08-08-2012 04:21 PM in reply to: JohnK_TEDCF
    Thanks but I think the problem is there really is nothing around that goes beyond what you can't work out on your own by trial and error and help files. The AU class on iLogic Made Simple is no different.
    Stew, AICP
