• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Hintehoeller, Richard
    what is that trick for making the holes come out right in theFP
    11-04-2002 09:13 PM in reply to: *Mayfair, John
    Larry:
    Spent the weekend installing IV6 and messing around with with my
    network. I finally got the network up to the point where I could
    download your 'SM Folded Cone Passthrough.ipt'.
    Very nice. What was I thinking with all those equations when adding
    faces automatically invokes the 'Bend' command. Learn something new
    every day.
    So I blended your solution with mine and thought you might like the
    concept. The general outline is:
    1/ Use the steps you took to create the first face, however, only create
    half of the trapezoid.
    2/ Create the second face, and again create only the trapezoid. You now
    have 1/24th of the 'Cone'. Obvously the two half-trapezoids have to be
    adjacent.
    3/ In an assembly, array 24 instances of the cone about the central axis.
    4/ In a new part, derive the assembly.
    5/ Extrude a narrow slot in one face.
    6/ Cut all of the holes.
    7/ Flat pattern.
    The advantages are that it saves creating 22 workplanes and sketches,
    and once the link between IV6 and Excel gets patched, a spreadsheet
    could be used to drive the whole shebang.
    Richard
    Please use plain text.
    *Caldwell, Larry
    11-05-2002 01:24 AM in reply to: *Mayfair, John
    That would work as well. I thought about making a pattern and deriving it
    but thought it would better demonstrate, to John, how it would be done as a
    regular part since he's new to Inventor. Funny thing, though, there doesn't
    seem to be enough material to support the through holes being at the
    specified angles/heights. I adjusted the angle of all the holes to keep the
    small holes on the pattern but the big holes cut through the edge of the
    material and couldn't be rotated enough to stay on the flat pattern. Still
    don't know what the reason is but I figure the angles have to be called out
    wrong or the small end is too small. Who knows?
    Interesting cliché, that: I always assumed that everything I learned was
    new.
    ~Larry
    "Richard Hintehoeller" wrote in message
    news:3DC7C411.9020903@hfx.eastlink.ca...
    > Larry:
    > every day.
    > adjacent.
    > 7/ Flat pattern.
    > Richard
