Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
visibility in 2d drawings
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This is probably a question with a simple answer that I haven't found the answer to. I want to be able to hide a part of an assembly in one projected view of the 2d drawing but not all, however when I do so the hidden lines stay hidden lines. They do not change. I know you can change the hidden line properties to make them continuous lines but is there a setting that will allow these lines to change automatically?
Re: visibility in 2d drawings
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
umm..something else must be wrong. When you remove the visibilty of a part that was over other parts the hidden lines will change to continuous lines automatically. What version of Inventor are you using?
2012 Product Design Suite Ultimate
Windows 7 64 bit
90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Could you attach some images or drawings for more details?
River Cai
River Cai
Quality Assurance Team
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I attached an inventor drawing that has the hidden line problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi! Please attach the model file (ipt or iam) too. IDW file is not enough to see the drawing views.
Thanks!
Principal SQA Engineer, Inventor
Manufacturing Group
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Here is the part file
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
hoaglin,
1 part and 1 idw is not enough to show the problem.. You need to attach an iam and all the ipts in that plus the idw and a screen shot would be nice too showing the issue. I suggest you zip up all the parts/iam/idw/screenshot and post that.
For your reference an idw (or iam) is simply a file with links/references to all the files in it.. they are not included in the idw (or iam) file itself. So for example if you have a problem with an iam file you need to include that iam file plus all the ipts in it.
Windows 7 64 bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hopefully this is everything. I just want to know how to hide a part in a drawing file without leaving hidden lines behind.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I assumed the original state of base view shows in the attached image.
1. Please right-click the component in browser which you want to hide in the view.
2. Select "Select as Edges" in context menu
3. Right-click the highlight edges in view, select "Visibility"
You will see all the project edges from the selected component will be invisible. When the invisible edges are expected to show, please right-click the view then select "Show hidden edges", and right-click the highlight edges in view to select "Show All" in context menu.
River Cai
River Cai
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
An easy way to hide a part is,
1. Select the part node on browser under the projected view
2. Uncheck "Visibility"
Best Regards,
Raymond Xu
Senior Software Engineer
Manufacturing Industry Group
