• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Accepted Solution
    view representations
    152 Views, 6 Replies
    05-03-2012 07:59 AM
    In regards to assemblies:My small assembly contains about 30 separate parts and all in a dark blue color.I want to make the same assembly the color Green and another the color Black.
    Do i follow the following steps
    1. Do i RMB on View:Master and select NEW
    2. Select all the parts and change to desired color
    Have i missed anything
    Regards
    Simon,
    Inventor 2012
    Please use plain text.
    *Expert Elite*
    Re: view representations
    05-03-2012 12:28 PM in reply to: simon_toaldo
    Make sure it is design view representations you are using and NOT level of detail.
    Make sure the new rep is active when you select the parts to colour.
    Then make another new rep, set active and change the colours again.
    You need to have one rep for each colour.
    You can also rename the rep to match the colour for ease of recognition.
    These reps can then be selected in higher assemblies to give the colour you choose, you will also need reps in the higher assembly to hold the chosen colour rep.
    Drawings also use the reps for views and for driving part list filters.
    *Expert Elite*
    05-03-2012 02:02 PM in reply to: harco
    Really it depends.. Should each color variation of each part have a separate part number?
    Or is the whole assembly painted after it is all assembled?
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    Valued Contributor
    05-04-2012 07:13 AM in reply to: mcgyvr
    I made up a quick example of a assembly and created 1 in Blue and 1 in Black.I named 1 view as Blue and 1 view as Black...I just then select the color view i want and activate and the color works.If this is the correct way you explained then i can go ahead and do this to my assemblies
    Regards
    Simon
    *Expert Elite*
    05-04-2012 07:26 AM in reply to: simon_toaldo
    You didn't answer these questions
    1-Should each color variation of each part have a separate part number?
    2-Or is the whole assembly painted after it is all assembled?
    Nevermind.. I see you are a student and buying/stocking/inventory is probably not a concern of yours.. So then yes.. The example you posted is correct for this situation.
    Windows 7 64 bit
    Valued Contributor
    05-04-2012 07:30 AM in reply to: mcgyvr
    Ok...
    Q1 - no
    Q2 - yes
    Regards
    Simon
    Valued Contributor
    05-09-2012 08:10 AM in reply to: simon_toaldo
    Thank you mcgyver and harco
