• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Land, Brian
    video card positive
    60 Views, 12 Replies
    10-31-2002 09:20 PM
    just wanted to say that my quadro 750 xgl is working great on r6... using
    driver 30.82... i'm verrrry happy, because i was dissapointed in its
    performance when i purchased it for 5.3. Couldn't tell a noticeable diff.
    before from my old GVX1.
    Brian Land
    Mechanical Design
    Lorik Tool Inc.
    Please use plain text.
    *Dotson, Sean
    Re: video card positive
    10-31-2002 09:25 PM in reply to: *Land, Brian
    I'm assuming that driver would also work with the 700XGL? Maybe I'll need
    to check that out..
    Sean Dotson, PE
    http://www.sdotson.com
    remove all #s from email
    "Brian Land" wrote in message
    news:E16B8E1EBB48D29E47AC9410931715F2@in.WebX.maYIadrTaRb...
    > Brian Land
    > Mechanical Design
    > Lorik Tool Inc.
    *Zirkle, Eric
    Re:
    10-31-2002 09:39 PM in reply to: *Land, Brian
    Anyone using a 900XGL?
    "Sean Dotson" wrote in message
    news:CF7D967AC0195AA46086A256E7DD6538@in.WebX.maYIadrTaRb...
    > to check that out..
    > Sean Dotson, PE
    using
    diff.
    > > Brian Land
    > > Mechanical Design
    > > Lorik Tool Inc.
    *Friedman, Aaron R.
    10-31-2002 11:59 PM in reply to: *Land, Brian
    What OS?
    -ARF
    > Brian Land
    > Mechanical Design
    > Lorik Tool Inc.
    *Dotson, Sean
    11-01-2002 12:02 AM in reply to: *Land, Brian
    I upgraded to this driver but still see some slight lagging in the sketch
    environment. I think I may just wait to see if SP1 clears it up.
    Sean Dotson, PE
    > Brian Land
    > Mechanical Design
    > Lorik Tool Inc.
    *Land, Brian
    Re:
    11-01-2002 12:22 AM in reply to: *Land, Brian
    win 2000, custom opengl settings set to (don't ask why...long story)
    softimage, full optimization selected in inventor...... Sean said he saw
    slight lagging in sketch mode, i do see a little of that also, but overall
    performance is good.
    "Aaron R. Friedman" wrote in message
    news:3DC2A4FE.7000201@xprt.net...
    > What OS?
    > -ARF
    using
    diff.
    > > Brian Land
    > > Mechanical Design
    > > Lorik Tool Inc.
    *Mclean, Colin
    Re:
    11-01-2002 02:05 AM in reply to: *Land, Brian
    I ' sure there are a few that are having no hassles with graphics, but only
    a few. This means there is something on the pcs of the masses, that
    conflicts with Inv 6 graphics. Another app . direct 3d or something. Never
    the less Autodesk need to find out what that is, and I bet its common to OS
    as we all have one of those. We see when SP1 arrives
    Colin
    news:E8CCB691F1F810E8ECBBDCA4055EE725@in.WebX.maYIadrTaRb...
    > Sean Dotson, PE
    using
    diff.
    > > Brian Land
    > > Mechanical Design
    > > Lorik Tool Inc.
    Active Contributor
    Re:
    Hey guys,
    this is all confusing with certified drivers and stuff. For best use of NV25GL (Quadro 4) core you should install drivers of version 40.71. I noticed a slightly performance increase from 30.82 to 40.71. If it is viewport performance that is bugging you, you can always try to overclock you´re Quadro by a LITTLE. Rivatuner can overclock on low hardware level, no reboot or whatever is required. That´s what I´ve done back in my Quadro 2 MXR days and it helped a lot in viewport performance.
    In OpenGL properties make sure that you dissabled vsync. Overclocking can be made by doing 10 Hz increments by core and memory values. When you reached point of instability drope down the frequencies by 15 or 20 Hz.
    regards
    *Crain, Ron
    Re:
    11-01-2002 03:17 AM in reply to: *Land, Brian
    I am currently using version 40.72  as I was
    told it is the only driver version nVidia will fix if problems are
    found.
    Hey
    guys,
    regards
    *Frodason, Finnur P.
    Re:
    11-03-2002 07:36 PM in reply to: *Land, Brian
    Yes, without a glitch. I'm using the 30.82 driver og W2K + sp3 and EI 6 +
    sp1
    Dual Xeon 2.4 with 2 Gb mem. swapfile is static on physical disk no. 2.
    I have never had any games /direct 3D applications on my machines. I wonder
    it that could be the difference?
    Regards
    Finnur P.
    "Eric Zirkle" <@> wrote in message
    news:smileyvery-happy:CA38945B4AF2B9A22F30C305D532D0D@in.WebX.maYIadrTaRb...
    need
    > > to check that out..
    > > Sean Dotson, PE
    > using
    > diff.
    > > > Brian Land
    > > > Mechanical Design
    > > > Lorik Tool Inc.
