• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    using a VB.net form with iLogic (Tutorial)
    313 Views, 2 Replies
    11-29-2012 03:14 PM
    Hello All.
    I have been using ilogic and Inventor VBA for a few months now, but I still consider myself fairly new to VB.Net
    My objective is to create a form in VB.net (using Visual Studio) (As the dynamic nature of the form I need for this project exceeds the capability of the form generation tool provided with iLogic)
    With Inventor install (2012) came bundled a few iLogic samples. I took a few hints from the "Railing iLogic Sample Advanced.iam" but I am still trying to figure out how does the VB.net-form communicate with (iLogic) parameters of the inventor file. (I don't know what contents does a .dll carry over from a VB.net project)
    Should use:
    Dim oUserParameters as UserParameters
    Set oUserParameters = invApp.ActiveDocument.ComponentDefinition.Parameters.UserParameters.Item("xxx")
    ...to change the parameters' values (embedded within the code of the form) or if anyone could explain (or point me towards a blog/tutorial) on how iLogic can read from the form.
    I can use the trick explained in this post ("My first plug-in)
    http://forums.autodesk.com/t5/Autodesk-Inventor/Check-out-the-self-paced-guide-My-First-Plug-in/td-p...
    ... but I think I would like this projects applicaion restricted to a single Assembly (.iam file) only.
    Both short and long responses will be helpful;
    and is appreciated. Thanking you,
    Wajih
    Please use plain text.
    Valued Mentor
    Re: using a VB.net form with iLogic (Tutorial)
    11-30-2012 08:06 AM in reply to: WHassan
    hi, it may be quicker if you post in the customisation area of the inventor forum... just one click away from here.
    if i knew a bit about iLogic i would to help but unfortunately i can't. the inventor VBA may help if you want to look into that as well.
    -Mark
    Inventor 2014 Pro on Windows 7, 64bit
    (please give Kudos or Tag as Solved if your issue is resolved)
    Active Contributor
    11-30-2012 09:09 AM in reply to: Mark_Wigan
    Will do that Thanks Mark,
    Wajih
