• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    unavailable project locations
    471 Views, 2 Replies
    03-28-2011 05:39 AM
    I have started seeing this message "The following location(s)  in your project are unavailable. If you continue opening the file, you may experience significantly slower performance than normal. Library    C:\Vault\Library". I haven't changed anything that I'm aware of.  Can someone tell me how to correct this?
    Please use plain text.
    ScottMoyse
    Re: unavailable project locations
    03-28-2011 11:19 PM in reply to: mjgky30SA
    have you cleaned your workspace recently? That may have removed the folder, also i seem to remember there being a setting in vault somewhere, that may purge files from local workspaces over a certain age. I didn't think it deleted folder structures though.
    I would say purely based on that message, that the folder doesn't exist anymore. Have you tried to browse to that location using windows explorer?
    Cheers
    Scott Moyse
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
    08-01-2012 09:00 AM in reply to: ScottMoyse
    I am having this same problem and the file the warning mentions has indeed been deleted. Do you know how I can get that folder back? It is the Libraries folder, I have tried just creating an empty folder in this location but that did not work. Any ideas?
