Autodesk Inventor
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
*Gaets
twisted flat bar
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
142 Views, 2 Replies
11-03-2002 02:53 AM
How do I model the following??
In elevation I have a 1 in wide by 1/4" thick flat bar by approx 6 in long
set a 60deg from horizontal
At the top end the bar is bent down to horizontal and twisted 90 deg flat 2
in long.
How do I model the twist and bend ???? (sounds like a new dance)
Thank you
Gaets
in long.
Thank you
Gaets
*Howard, Jeff
Re: twisted flat bar
Options
- Highlight
- Email to a Friend
11-03-2002 11:16 AM in reply to:
*Gaets
See CF. It can also be done just by lofting between the two extrusions with
square cut ends and no intermediate profile, but it's not very pretty.
Don't make sketches on the extrusion ends, just pick the faces for profiles.
Delete the existing flow (transition) lines; clear Auto Mapping, select "Set
x" and press the key, then add flow lines as desired.
Jeff
"Gaets" wrote in message
news:7A23B0FE586A0C8973B0BE15548C897E@in.WebX.maYI adrTaRb...
in long.
Thank you
Gaets
x" and press the
Jeff
"Gaets"
in long.
Thank you
Gaets
*Gaets
Re:
Options
- Highlight
- Email to a Friend
11-03-2002 09:13 PM in reply to:
*Gaets
Thank you
Gaets
"Jeff Howard" wrote in message
news:3BCE6FB608E90EA3194DB1ABE347083C@in.WebX.maYI adrTaRb...
with
profiles.
"Set
> Jeff
2
> in long.
> Thank you
> Gaets
Gaets
"Jeff Howard"
with
profiles.
"Set
> x" and press the
> Jeff
> "Gaets"
2
> in long.
> Thank you
> Gaets
