Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
tube % pipe versus individual pipes
- Highlight
- Email to a Friend
I habe a machine which required various size pipes.The machine area is 7m x 2m.....I ususally design each individual pipe...is this better to do with pipe and tube or should i continue to create each pipe individually....I have created all the valves which i use in the machines......can these be inserted using Pipe & Tube?
Any advantage of pipe and tube over individual creation of pipes in machines of this size
Thank you
TH
Re: tube % pipe versus individual pipes
- Highlight
- Email to a Friend
The T&P module is really just a "short-cut" and has some specific tools to aid in 3D sketching for the create of the T&P runs.
If you are just using straight pipes and have placed all your fittings, maybe think of using the Content Center for your pipes. You can simply RMB on the CC pipe within the assembly and change it's size or length from the screen pop-up dialogue box.
It also has a number of benefits in the IDW's BOM as well.
IV2014.1 PDSU / Sim Mech 2014 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 314.07
SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
- Highlight
- Email to a Friend
In my humble opinion, the benefits of T&P vs individual pipes using standard constraints depends greatly on the amount of piping you need to run. If your machine is heavily piped as ours are, they are a nightmare to do with standard constraints. T&P does have some limitations and can be a hair pulling experience at times... but there's no way I'd go back with the amount of piping we do on a daily basis. And yes, your custom valves and fittings can be authored and added to the Content Center to be used with Tube & Pipe fairly easily.
So it all depends on the nature and amout of piping you need to do.
- Highlight
- Email to a Friend
Thanks Blair
Hi Chris
Thank you
Would you have a picture of your machines
Thanks again
Tony
- Highlight
- Email to a Friend
We do commercial transport trailers, so most of our T&P is flexible lines.
Win7-64
- Highlight
- Email to a Friend
very impressive
