• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    tolerance analysis
    230 Views, 3 Replies
    11-12-2003 01:20 AM
    Hello, I'm a MDT 6 user and I was just wondering if Inventor had means to perform tolerance analysis on an assembly. The MDT way to do this is very cumbersome so I was looking at new software but will use inventor if it can do the job.
    Please use plain text.
    *RuiF
    Re: tolerance analysis
    11-12-2003 04:09 AM in reply to: jstraitiff
    If you mean setting dimensions at maximum or minimum tolerance, IV can do
    it.
    Rui
    "jstraitiff" wrote in message
    news:f19c292.-1@WebX.maYIadrTaRb...
    do the job.
    New Member
    10-23-2012 07:20 AM in reply to: jstraitiff
    Is there any ability to do a tolerance analysis with GD&T?
    Distinguished Contributor
    Ryan.Martinez
    10-23-2012 07:27 AM in reply to: kdwynn
    Not that I know of. That would be a pretty cool and useful feature to have.
    You  can set tolerances to min/max/median/nominal and then check for interferance in the assembly environment.
    Product Design Suite 2013
