• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    na57zim12
    sweep problem
    202 Views, 10 Replies
    07-20-2011 01:49 AM
    I am having problem with my sweep, My trajectory profile path is on the surface and the othe other one is trajectory but it doesn't work
    please help me
    Please use plain text.
    Active Contributor
    na57zim12
    Re: sweep problem
    07-20-2011 01:53 AM in reply to: na57zim12
    I want to make a part like this
    Active Member
    Re: sweep problem
    07-20-2011 01:56 AM in reply to: na57zim12
    The way I see it, create a tooth first and then circular array it.
    Greetings,
    E. Peter
    Autodesk Inventor Ultimate 2012
    Active Contributor
    na57zim12
    Re: sweep problem
    07-20-2011 02:49 AM in reply to: eddy
    how to do this, i am working on it 3 days.
    by sweep or anyother ?
    sam_m
    Re: sweep problem
    07-20-2011 03:25 AM in reply to: na57zim12
    and which version of Inventor???
    Only going to annoy people if they spend time creating an example for you to say you're on a previous version and can't open it.
    Please mark this response as "Accept as Solution" if it answers your question - but note that the solution may not be the answer you're wanting to hear...
    Lithium - helping nntp users with mania, depression and headaches
    sam_m
    Re: sweep problem
    07-20-2011 03:31 AM in reply to: na57zim12
    looking at the dwf I dont think sweep is the answer (and I'm wondering how it will mould).
    personally would use surfaces as each "tooth" looks like a extrusion (presumably with a taper to be moulded) but instead of being a distance it's "to" a surface revolved around the body.
    1) revolve body
    2) revolve curved top of tooth as a surface
    3) create a sketch on the base and extrude a tooth to the surface
    4) create the hole on the inside
    5) pattern extrusion and hole
    MariaManuela
    Re: sweep problem
    07-20-2011 03:32 AM in reply to: na57zim12
    You can try create a Loft feature starting in your sketch15 and end in a point (points also available to create Loft features) and then by giving the centerline to better control the loft shape.
    Maria Manuela Pinho
    Application Enginner
    Cadtech.Asidek | Autodesk Gold Partner
    http://cadtech-asidek.blogspot.com/
    www.cadtech.pt | www.cadtech.es | www.asidek.es
    Autodesk Inventor Professional 2013
    Windows 7 Professional 64-bit
    Active Contributor
    na57zim12
    Re: sweep problem
    07-20-2011 03:36 AM in reply to: sam_m
    inventor pro 2012
    sam_m
    Re: sweep problem
    07-20-2011 04:12 AM in reply to: na57zim12
    I'm on 2011 so can't open your ipt and edit it.
    here's a quick bodge that kinda resembles the dwf.  Tbh, with more time I'd redo it and probably come up with something cleaner (especially for the tangent of the top surface to the draw-angle of the extrusion).
    1) revolve the body
    2) revolve a surface for the top of the tooth
    3) extrude a surface for the exterior of the tooth
    4) create "inside" surfaces of the above
    5) sculpt a solid tooth
    6) sculpt away the inside of the tooth
    7) fillets
    8) pattern sculpts and fillets
    quick and dirty but might give you some ideas how to do it on your model.
    (still have no idea how you would expect this part to be moulded/made though).
    Valued Mentor
    Re : sweep problem
    07-20-2011 04:45 AM in reply to: na57zim12
    Hi
    To achieve your sweep roll up the EOP below sketch 15
    create intersection point(working point) with construction plane 15 and radius on sketch 15
    after edit the sketch 16 and apply coincident constraint on end line and projected working point
    try to built your loft with parallel condition and that's it
    after use sculpt feature.
    Yannick Verreault
    Inv. 2012 ultimate
    Inv. 2011 pro sp2
    MS Office 2007
    Win 7 pro, core i7 950, asus P6T WS
    nvidia Gforce GTX 295
    WD caviar black 500Go
    WD caviar black 1To
