• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Employee
    Re: surface visability in an idw
    10-23-2012 09:15 PM in reply to: rhasell
    Hi Reg,
    No problem. Hope that works out. Sorry I forgot to address you in my post.
    -Shiva Sundaram
    Inventor Development
    Please use plain text.
    Distinguished Contributor
    slphantom
    10-24-2012 11:06 AM in reply to: Shiva_Sundaram
    so now i have an existing assembly idw and i added this part i downloaded from a vendor site and it does not show up on the idw views. how do i fix this?
    Scott
    win 7 64 bit
    xeon cpu 3.2 GHz
    quad core
    12 gig of ram
    Autodesk product design
    suite premuim 2013 64bit
    Nvida quadro fx3800
    Space Pilot ver. 1.6.2 2010
    slphantom (NNTP handle: scottl)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as scottl
    Employee
    10-24-2012 11:13 AM in reply to: slphantom
    Hi Scott,
    Does it appear if you create a new view? If so, then you may want to check to see if the drawing view (which doesnt show the part) has Associative DV = ON (view dialog has a checkbox). If its unchecked, you click on that to make the view associative, the part should become visible by default whenever any part is added to the assembly.
    OR you can re-apply design view to an existing drawing and right click context menu.
    OR you can select the part from the browser and turn visibility ON (if its off)
    If new drawing views also do not  show that, then it might be a problem with the part and I would be happy to take a look at if you want to email it to me - sundarsATautodeskDOTcom
    -Shiva Sundaram
    slphantom
    10-24-2012 11:53 AM in reply to: Shiva_Sundaram
    it shows it as on in my idw browser and if i create a new view of the same it shows up. i got it to show up in other views so just that top level assy idw. i can work around it.
    thanks
    Scott
    win 7 64 bit
    xeon cpu 3.2 GHz
    quad core
    12 gig of ram
    Nvida quadro fx3800
    as scottl
    rhasell
    11-05-2012 03:30 PM in reply to: slphantom
    Hi
    Back again. How do you set the view rep for Assemblies?
    The parts have the surface switched off, the surfaces are not visible in the assemblies, you can't acces the suface in the assembly tree either, but yet they all come through in the IDW?
    Regards
    Reg
    Autodesk Product Design Suite Premium 2013 sp1.1 (1)
    Intel Core i7 (950@3.07GHz)
    Windows 7x64 (Home)
    12GB Ram
    Nvidia GeForce GTX 560 Ti (1Gig - Ver:314.07)
    Employee
    11-05-2012 03:46 PM in reply to: Shiva_Sundaram
    Hi Reg,
    Did you try creating a drawing view with the View Representation CHECKED. The view create/edit dialog should contain a checkbox and if you click on it, it will use the view rep from the assembly document. Make sure that when you create or edit the drawing view, you select the view rep (in the list) which corresponds to the one which has surfaces off.
    I know it's a little confusing and change in behavior....
    Thanks and hope that helps....
    -Shiva Sundaram
    Active Contributor
    cellt2
    11-05-2012 05:01 PM in reply to: Shiva_Sundaram
    I don't think this is just "confusing" or a "change in behaviour".  This is a major addition to the work load and I cannot understand what has possessed AD to hobble its users this way.
    rhasell
    11-05-2012 09:46 PM in reply to: Shiva_Sundaram
    Thanks Shiva
    I will try the different workflow.
    I gave the workflow a quick test, and guess what, it all worked 100%
    The Assiciative check box was not ticked, on that particular drawing, I will keep you updated if find anything strange.
    Applying "All surfaces" view rep is still quite painfull.
    tx
    Regards
    Reg
    Windows 7x64 (Home)
    12GB Ram
