• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    j.vanderheijden
    suppress flanges
    106 Views, 1 Replies
    11-15-2012 01:18 PM
    I am trying to make a way that suppress the flange features of all the panels that will be insert in the assy so i can suppress al the features at ones in a assy and don't have to do that for each panel separately.
    I have a assy with parameters and i have a part with no geometry but have linked the parameters from the assy.
    In my panel part i link the parameters to the part with no geometry.
    When i use the parameter in the assy to suppress the flanges that works the way i want it.
    But when i insert the panel part into that assy it dus't work.
    I think i miss a link, can anybody help me out?
    Mvg Jos
    Your drawings are only as good as the symbols that complete them...
    Please use plain text.
    j.vanderheijden
    Re: suppress flanges
    11-20-2012 12:41 PM in reply to: j.vanderheijden
    I am now ready to succeed to suppress the flanges off the parts in my assy.
    The problem now is that if I place a panel with 'Place' it goes well even if I use a different type of panel.
    But if I place the panel on "Place iLogic Component" then it does not work.
    The panel is the same as when I was with 'Place' insert.
    Everything is linked to the same parameters and the same part,  the part 'Koppeling'.
    Can somebody help me out.
    Mvg Jos
