• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    suppress bom info (filename, stock number, etc) when publishing to dwf
    124 Views, 4 Replies
    12-14-2012 07:14 AM
    When I publish from Inventor to DWF (including sheets in the idw and an view of the iam assembly file) numerous part properties are included in the dwf that I would like to strip out so we don't share too much info with.
    For example, filenames are included, stock numbers the complete bom from the model (as opposed to the parts lists that are shown in the idw's...  This info shows in the structured bill, and if you click on a part in the iam.
    How do I filter all this out so I only show part numbers and descriptions in iproperties?
    Thanks.
    Please use plain text.
    Cadmanto
    Re: suppress bom info (filename, stock number, etc) when publishing to dwf
    12-14-2012 08:27 AM in reply to: je10020
    Would creating a pdf work for you?
    A pdf won't carry those properties along.
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
    blair
    12-14-2012 08:43 AM in reply to: Cadmanto
    Can you not select the properties you wish to publish from the Properties tab of the DWF. The default is "Only properties with values". You can select the Radio Button just below it and then select which items you wish to include
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    12-14-2012 08:52 AM in reply to: je10020
    Thanks for the reply. I tried the radio buttons -  "select publish options" > check "custom" button > Properties Tab >  check button that allows values to be individually selected.
    Even after doing this the tables, filenames, other properties I though I had filtered were still visible when I opened the dwfx in design review.
    PaulMunford
    12-17-2012 02:28 PM in reply to: je10020
    You might find this article helpful.
    www.augi.com/library/the-truth-about-sharing-inventor-data
    The CAD Setter Out Blog
    @CadSetterOut
    Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
