• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    sprockets
    224 Views, 9 Replies
    01-15-2013 08:05 AM
    Does anyone have a good place to get 3d models of roller chain sprockets? I've been looking for a while now but i can't find anything that provides the variety or accuracy i need.
    Please use plain text.
    Distinguished Contributor
    Mason-Paul
    Re: sprockets
    01-15-2013 08:21 AM in reply to: danielw88
    You might like to try here http://grabcad.com
    Thanks in advance for any help & advice
    Inventor 2012 Pro
    Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
    Re: sprockets
    01-15-2013 08:35 AM in reply to: Mason-Paul
    They had alot, but not what i needed.
    Re: sprockets
    01-15-2013 08:40 AM in reply to: danielw88
    Re: sprockets
    01-15-2013 09:06 AM in reply to: danielw88
    Are you aware that there is a sprocket generator built into Inventor?
    I have an Excel driven sprocket based on Machinery's Handbook specs that you might be interested in if the Design Accelerator sprockets won't work for you.  You might have to edit it to meet your needs.
    Give me sample specs for one that you need.
    Re: sprockets
    01-15-2013 09:10 AM in reply to: JDMather
    I haven't used the sprocket/chain feature in Inventor for a while. The last time i used it, if i can recall correctly, generated a pair of discs (with not teeth) with a blue, transparent chain mock-up.
    The sprockets i need are H80B48, H80B15, H60B60
    Re: sprockets
    01-15-2013 09:12 AM in reply to: danielw88
    My memory isn't that great - but I don't recall a release that didn't generate real teeth.
    I have never bothered to check the DA generated toothform against my Machinery's Handbook spec generated toothform as sprockets are generally purchased off the shelf and my purpose for doing the geometry myself was simply to use something interesting to demonstrate how to create an iPart.
    The chain is generated as a simplified blue, tranlucent representation.
    Re: sprockets
    01-15-2013 09:17 AM in reply to: JDMather
    Then your memory is better than mine because i just checked and the generator does include teeth on the sprocket discs.
    Thanks for your help, other than not having a hub, those sprockets will serve their purpose. I can't belive i had forgotten about that feature.
    Re: sprockets
    01-15-2013 09:23 AM in reply to: danielw88
    Simply edit the part to add hub and hole as needed.
    BLHDrafting
    Re: sprockets
    01-15-2013 06:00 PM in reply to: danielw88
    I give a thumbs up to Traceparts.Has all the sprockets I could ever need.
    http://www.tracepartsonline.net
     Do a search or look in here :-
    Mechanical systems and components of general use > Flexible drives and transmissions > Chain drives and their components >
    Brendan Henderson
    Web www.blh.com.au
    Twitter @BLHDrafting
    Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
    ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD
    Inv R2013 PDS SP1.1 Update 2, Vault 2013 Workgroup Update 1
