• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    splitting curved faces into two faces
    172 Views, 1 Replies
    01-11-2013 08:13 PM
    i got Inventor recently, and i've been working on a model of a longboard just to teach myself how to use the tools in Inventor. right now i'm trying to color areas for the griptape pattern so i drew the 2D pattern and projected it onto the 3D model of the longboard. but when i tried to split the faces of the model along the projected pattern only a few of the projected lines split the faces. for other faces i kept getting these errors:
    Create parting line failed
    Crane.ipt: Errors occurred during update
    Split11: Could not build this Split
    The attempted operation did not produce a meaningful result. Try with different inputs.
    i have no idea what to do to fix this. help?
    Please use plain text.
    Re: splitting curved faces into two faces
    01-12-2013 10:11 AM in reply to: thatnewguy
    You do not have to create a 3D sketch - you can split a part face directly with a 2D sketch.
    My recommendations:
    You are doing wayyyyyyyy too much work.
    Go  through the built in Help>Learning Tools>Tutorials and Skillbuilders
    Go through http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
    Go through http://inventortrenches.blogspot.com/p/inventor-tutorials.html
    Go through the rest of the tutorials in my signature and THEN come back to this project that you are working on.
    Inventor Professional 2014 Edu 64-bit
