• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    JimSteinmeyer
    Accepted Solution
    split edge for radius
    104 Views, 5 Replies
    02-08-2012 09:21 AM
    I would like to radius the edge of a block for about 1" along a 3" edge. In Solid-doesn't-Works I would select an eddge to radius and then would edit it pulling one end of the line to radius back to the desired length of the radius.Here I find no option to edit the edge, I have also tried splitting the edge but I can't seem to make that feature work. Is there a way to do this short of creating a work plane at one end of the edge and then creating a cut to a set depth?
    Thank you
    Jim
    Jim
    Inventor 2012 SP1
    Vault 2012- plain vanilla version
    HP G71 notebook
    celeron cpu w\ 4gb RAM and 64 bit system
    Win 7 home premium
    Ya, my boss has me running my personal machine at work.
    Distinguished Mentor
    MariaManuela
    Re: split edge for radius
    02-08-2012 10:05 AM in reply to: JimSteinmeyer
    Can also with Multi Body modeling. I know that is not the ideal tool. Better than nothing.
    Maria Manuela Pinho
    Application Enginner
    Cadtech.Asidek | Autodesk Gold Partner
    http://cadtech-asidek.blogspot.com/
    www.cadtech.pt | www.cadtech.es | www.asidek.es
    Autodesk Inventor Professional 2013
    Windows 7 Professional 64-bit
    02-09-2012 03:59 AM in reply to: JimSteinmeyer
    Splitting the edge is a good way to accomplish this.  But you also have to expand the Fillet dialog box (>>) and turn off the Automatic Edge Chain so it won't automatically string all tangent edges together.
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2012 SP1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool
    JimSteinmeyer
    02-09-2012 08:05 AM in reply to: sbixler
    Sorry, i selected accept rather than reply.
    I have two questions. I have attempted to split the edge but the split tool  wants to split the face. Is this the correct procedure, or is there a way to split just the edge?
    Second. When I looked at the drop down for the radisus the button for turning off the automatic edge chain was grayed out. does this only come active if the edge is split?
    Thank you
    Jim
    Jim
    Inventor 2012 SP1
    HP G71 notebook
    Win 7 home premium
    02-09-2012 08:14 AM in reply to: JimSteinmeyer
    1. Right, you can only split faces or solids, not edges.
    2. I'm guessing that you have an edge selected when you see this.  I believe that it's only active when you have nothing selected.  Easy to accomplish, though-- hold the Ctrl key down and pick the already selected edge(s) to deselect everything, then you should be able to change the automatic edge chain option.
    Sam B
    JimSteinmeyer
    02-09-2012 08:18 AM in reply to: sbixler
    Thank you
    Jim
    Inventor 2012 SP1
    HP G71 notebook
    Win 7 home premium
