• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Contributor ian
    ian
    simple frame generator project. best way to do this?
    293 Views, 4 Replies
    06-26-2011 04:20 PM
    i need to build about 8 versions of this simple box (see pic). base size, top size height... easy!
    i have been using simple extruded boxes for most of my work to create the "path" of the frame, but with the tops being smaller than the base i need a new trick. also i know i will make more and more versions and would like to make new sizes a quick and simple job.
    thanks!
    ian
    Please use plain text.
    Valued Mentor
    Re: simple frame generator project. best way to do this?
    06-26-2011 05:43 PM in reply to: ian
    Hi Ian,
    I personally would use iParts and iAssembly to do that job.
    Igor.
    Web: www.meqc.com.au
    Contributor ian
    ian
    06-26-2011 08:25 PM in reply to: ian
    ok, but im wanting to use the F.G. more as our shop uses steel tube  & pipe about 99% of the time.
    im messing around with this task and have now got a new question. how do i add to the exising ANSI tubes? i made a copy of the ANSI square shapes and then made a copy of the 2x2 3/13. i then edeted the 2x2 to be 1x1 and the wall to be .120. revised the corner rad and all looks good untill i use the tube... its showing up as 1x2....
    PaulMunford
    06-27-2011 12:54 AM in reply to: ian
    I would use iCopy, but then that's just me :smileywink:
    The CAD Setter Out Blog
    @CadSetterOut
    Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
    ianmacleanllc
    10-26-2011 06:27 PM in reply to: ian
    ok... so you all wanted to do it some other way. i get it.
    does anyone have anaswer as to how to di it with the frame generator and quickly make changes?
    height of box
    size of base
    size of top
    thanks
    -ian
