• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    alexpinedo5052
    shrinkwrap problem
    128 Views, 2 Replies
    11-19-2012 02:06 AM
    From an assembly I created a shrinkwrap part. In the options window, I modified the range to plug the holes (default range is 10-999999 mm). The problem is that every time I update the shrinkwrap part, the range changes to the default values.
    I am using Inventor 2013 and this problem didn't happen in a previuos versions.
    Any solution?
    Thanks.
    Please use plain text.
    Re: shrinkwrap problem
    11-19-2012 10:23 AM in reply to: alexpinedo5052
    Any solution?
    Thanks.
    I haven't checked to see if the problem can be reproduced in SP1.1, but that is the obvious first question - are you on the latest Service Pack?
    Member
    alexpinedo5052
    11-20-2012 12:35 AM in reply to: alexpinedo5052
    yes I am on SP1.1
    Thanks.
