• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    Valued Contributor ijc
    Valued Contributor
    ijc
    shell
    145 Views, 3 Replies
    10-03-2012 05:04 AM
    I`m trying to shell out the Neck on this volute but it does not work with the Shell feature.What can i do to get the Neck (sweep 1 ) to be Shelled out?
    The version attached is 2013
    IJC
    Please use plain text.
    Distinguished Contributor wh
    wh
    Betreff: shell
    10-03-2012 05:28 AM in reply to: ijc
    Perhaps this way ..
    Walter
    Re: shell
    10-03-2012 05:30 AM in reply to: ijc
    The Shell commands works on an entire solid body - not just a feature.
    Either - create that geometry first in your history tree and shell before creating the rest of the geometry
    or
    create that geometry as multi-body solids so that it can be shelled (you can then Combine if desired, but it looks to me like that should be multi-body anyhow).
    Hmmmp, looks like Walter modeled the solution while I was typing.
    Valued Contributor
    ijc
    Re: shell
    10-03-2012 05:38 AM in reply to: JDMather
