• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    sheetmetal flange - how to make this feature?
    223 Views, 2 Replies
    11-29-2012 07:45 AM
    Guys;
    I'm learning Inventor 2013 - I'm not new to 3D modeling or sheetmetal work, having used two other CAD programs over the last 15 years.
    See attached screenshot - I did this by manually putting in the reliefs, then adding a flange feature.  I want to do this by just putting the feature in, without manually creating the reliefs.  The "Flange" option doesn't seem to give me a way to put the feature on in any way other than along the entire edge.  After I put it on, I tried to go back and redefine it, but did not see a way to alter the width of the flange - it makes it the width of the entire edge that it's on. I tried to sketch a line where i wanted the flange to be, then use the "Fold" command; it goes through everything just fine and appears like it will work, but the result is a small bend completely along the edge again.  I tried the "Bend" command but apparently it will not do this either, as I can't satisfy the dialog box to even let me try it.
    I searched through this forum and online, and read the help file, but didn't come across this particular situation.
    -ungarata
    Please use plain text.
    Curtis_Waguespack
    Re: sheetmetal flange - how to make this feature?
    11-29-2012 07:52 AM in reply to: ungarata
    Hi ungarata,
    If you use the >> button at the bottom of the flange dialog box, you'll find the options you're after.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    11-29-2012 09:05 AM in reply to: ungarata
    Alternatively you could create that tab with a Face and select the edge for Bend.
