• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    JimSteinmeyer
    Accepted Solution
    sheet metal rule parameter
    119 Views, 2 Replies
    12-12-2012 01:33 PM
    When our VAR initally setup our system for us he made it so the material selected in with the sheet metal rule would appear as the stock number in the ipropertys. I then set the sheet metal rule so the sheet metal rule material also had our material stock number for each different thickness. This gave me a value that was automatically loaded for drawings.
         Now we have migrated to 2013 and in the migration things got mixed up so this no longer happens. I am assuming that when the SM Rule is set it creates a named parameter somewhere.Does anyone know what that parameter is? I am thinking if I go into the parameters of the template and set stock number = to SM Rule parameter I will regain this functionallity.
    Thank you
    Jim
    Inventor Premium 2013 SP1.1
    Vault 2013- plain vanilla version
    HP G71 notebook
    celeron cpu w\ 4gb RAM and 64 bit system
    Win 7 home premium
    Ya, my boss has me running my personal machine at work.
    Please use plain text.
    Valued Contributor
    Re: sheet metal rule parameter
    12-12-2012 02:49 PM in reply to: JimSteinmeyer
    It is a Property, not a Parameter. You should be able to get it by placing =<Sheet Metal Rule> in the Stock Number property.
    JimSteinmeyer
    12-13-2012 08:28 AM in reply to: nmunro
    Thank you
    Jim
    HP G71 notebook
    Win 7 home premium
