Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
sheet metal part
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi
How do i make the attach file as a sheet metal part?It takes a lot of moves to make as solid part..can it be made in sheet metal?
Regards
Simon
Re: sheet metal part
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You should be able to make this as a sheetmetal part. Start in the sheetmetal environment and instead of using extrude as your first feature, use the face tool. Instead of extrusion 2, use a cut. You could also use the face tool with the bend option to replace extrusions 5 & 6. Give it a try. When you get stuck, post what you've accomplished here and someone will help you out.
Jeff
Inventor 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I got to this point to sheet metal part.What steps should i now take to complete the rest of the part?
I am not sure how to create the sections which are bent
Appreciated
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Take a look at the attached file. It may give you some ideas.
Jeff
Inventor 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you,
Through your technique i made the next step but need help adding the last part to this.
CAn this when finished be flattened
Appreciated your help
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It will if you can keep the top of face4 straight. See the attached file.
Jeff
Inventor 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I added the last piece.Is this how you would have added this curved piece?
Thank you
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yup, looks good except sketch8 needs to be fully constrained.
Jeff
Inventor 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for your help Jeff
Merry Christmas
