• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Accepted Solution
    sheet metal part
    182 Views, 8 Replies
    12-20-2012 05:49 AM
    Hi
    How do i make the attach file as a sheet metal part?It takes a lot of  moves to make as solid part..can it be made in sheet metal?
    Regards
    Simon
    Please use plain text.
    Valued Mentor
    japike
    Re: sheet metal part
    12-20-2012 06:19 AM in reply to: simon_toaldo
    You should be able to make this as a sheetmetal part. Start in the sheetmetal environment and instead of using extrude as your first feature, use the face tool. Instead of extrusion 2, use a cut. You could also use the face tool with the bend option to replace extrusions 5 & 6. Give it a try. When you get stuck, post what you've accomplished here and someone will help you out.
    Peace,
    Jeff
    Inventor 2013
    Valued Contributor
    12-21-2012 03:01 AM in reply to: simon_toaldo
    I got to this point to sheet metal part.What steps should i now take to complete the rest of the part?
    I am not sure how to create the sections which are bent
    Appreciated
    Valued Mentor
    japike
    12-21-2012 04:46 AM in reply to: simon_toaldo
    Take a look at the attached file. It may give you some ideas.
    Peace,
    Jeff
    Inventor 2013
    Valued Contributor
    12-21-2012 05:13 AM in reply to: simon_toaldo
    Thank you,
    Through your technique i made the next step but need help adding the last part to this.
    CAn this when finished be flattened
    Appreciated your help
    Valued Mentor
    japike
    12-21-2012 05:29 AM in reply to: simon_toaldo
    It will if you can keep the top of face4 straight. See the attached file.
    Peace,
    Jeff
    Inventor 2013
    Valued Contributor
    12-21-2012 05:42 AM in reply to: simon_toaldo
    I added the last piece.Is this how you would have added this curved piece?
    Thank you
    Valued Mentor
    japike
    12-21-2012 05:51 AM in reply to: simon_toaldo
    Yup, looks good except sketch8 needs to be fully constrained.
    Peace,
    Jeff
    Inventor 2013
    Valued Contributor
    12-21-2012 05:54 AM in reply to: simon_toaldo
    Thanks for your help Jeff
    Merry Christmas
