• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    sheet metal extents add-in
    579 Views, 5 Replies
    07-03-2012 07:32 AM
    I am using IV ultimate 2013
    Hi just found about this add-in:http://modthemachine.typepad.com/my_weblog/2012/05/sheet-metal-extents-add-in-update.html
    But its not working for me:
    I ran the installer
    created a sheet metal part and hit rebuild all, it did not create any proeprties, also tried to manually create the properteis then hit rebuild, no go.
    I also did a search on my hardrive for the ApplicationPlugins, and placed the sheet metal folder in all of them(there were 3)
    tried again noto.
    The add-in also does not appear in the add-in manager.
    Any Ideas
    Or is there differnt wat to get the flat pattern dimensions in 2013
    TIA!
    Please use plain text.
    Curtis_Waguespack
    Re: sheet metal extents add-in
    07-03-2012 07:53 AM in reply to: omartin
    Hi omartin,
    If your goal is to show the flat pattern extents on the drawing then indeed this is built into Inventor now. You can do so by using the Text tool and pulling the Sheet Metal Properties as shown here.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    07-03-2012 08:14 AM in reply to: Curtis_Waguespack
    Hey Curtis thanks for they reply.
    But I plan on showing it in the BOM, Ideally it would be in the fxParameters (which I think this add-in supports)
    But I have some custom variables in my BOM that I use, and I am hoping I can point to those custom properties.
    I will keep on trying to figure it out.
    Regards
    Curtis_Waguespack
    07-03-2012 09:01 AM in reply to: omartin
    Hi omartin,
    If it helps, you can create a simple iLogic rule to place the extents information into custom iProperties that can be used in the BOM & Parts List. Attached is example with the rule placed in the part, but I'd recommend creating the rule as an external rule, so you can have it run on all sheet metal parts when they are saved, etc.
    http://inventortrenches.blogspot.com/2012/01/creating-basic-ilogic-rule-with-event.html
    Dim oDoc As Document
    oDoc = ThisApplication.ActiveDocument
    'make sure the part is a sheet metal part
    If oDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
    MessageBox.Show("This is not a sheet metal part.", "iLogic")
    Return 'exit rule
    Else
    Dim oSMDef As SheetMetalComponentDefinition
    oSMDef = oDoc.ComponentDefinition
    Dim sExtLength As String = "extents_length"
    Dim sExtWidth As String = "extents_width"
    Dim sExtArea As String = "extents_area"
    Dim iRoundValue as Integer = 2
    'check for flat pattern
    If oSMDef.FlatPattern Is Nothing Then
    'create a flat pattern if it doesn't exist
    oSMDef.Unfold
    oSMDef.FlatPattern.ExitEdit
    Else
    'define custom property set
    customPropertySet = ThisDoc.Document.PropertySets.Item _
    ("Inventor User Defined Properties")
    'look for custom iproperty and try to set it
    Try
              iProperties.Value("Custom", sExtLength) = Round(SheetMetal.FlatExtentsLength, iRoundValue)
    Catch
    ' assume error means not found and create it
                customPropertySet.Add(Round(SheetMetal.FlatExtentsLength,iRoundValue), sExtLength)
    End Try
    Try
              iProperties.Value("Custom", sExtWidth) = Round(SheetMetal.FlatExtentsWidth,iRoundValue)
    Catch
                customPropertySet.Add(Round(SheetMetal.FlatExtentsWidth,iRoundValue), sExtWidth)
    End Try
    Try
              iProperties.Value("Custom", sExtArea) = Round(SheetMetal.FlatExtentsArea,iRoundValue)
    Catch
                customPropertySet.Add(Round(SheetMetal.FlatExtentsWidth,iRoundValue), sExtArea)
    End Try
    End if
    End If
    I hope this helps.
    Curtis
    karthur1
    10-25-2012 11:57 AM in reply to: Curtis_Waguespack
    Curtis,
    How can I get this information (extents_length and Extents_width) to be written to the model user parameters instead of the custom iProperty parameters?
    karthur1
    10-30-2012 12:56 PM in reply to: karthur1
    Curtis wrote the iLogic code to get put this information in the User Parameters. Here is the thread that discussed doing this.  The code is attached below.
