• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Hidayah
    sheet metal corner joint
    443 Views, 9 Replies
    01-13-2013 05:43 PM
    Dear All,
    Can anyone help me on this?
    How to joint this corner together for becoming 45degree corner shape?
    See attachment and Inventor file.
    Please use plain text.
    *Expert Elite*
    blair
    Re: sheet metal corner joint
    01-13-2013 06:06 PM in reply to: Hidayah
    Expand the Hem command box and use the offset to create the hems. Then use the Corner command. I did a quick change to your base sketch to get the (sides) longer.
    The sketch is completely unconstrained, not good modeling practices.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    Active Member
    Hidayah
    01-13-2013 06:46 PM in reply to: blair
    Thanks a lots for the help! :smileyvery-happy:
    *Expert Elite*
    01-14-2013 07:46 AM in reply to: Hidayah
    I think you are doing too much work.
    There is an easier way.
    First thing I noticed is that your Sketch1 is not constrained.
    http://home.pct.edu/~jmather/AU2007/MA105-1L%20Mather.pdf
    Distinguished Contributor
    brendan.henderson
    01-14-2013 06:59 PM in reply to: JDMather
    I always enjoy you solutions. Buggered if I know how you did it with only 2 features though! Mind sharing the secret JD?
    Brendan Henderson
    CAD Manager/Product Development Manager
    HP Z420 Workstation, Windows 7 x64, 64 GB Ram
    Intel Xeon E5-1620 @ 3.60 GHz, ATI FirePro V7800 2 GB
    3*Dell 2007Fp monitors, SpacePilot
    Inventor 2013 PDS Premium & Service Pack 1.1 with Update 2
    Vault Workgroup 2013 with Update 1
    *Expert Elite*
    blair
    01-14-2013 09:18 PM in reply to: brendan.henderson
    here is a better one
    Win7-64
    *Pro
    01-15-2013 04:36 AM in reply to: brendan.henderson
    Here's one with the two features similar to JD's method (I presume).  This is done in 2013, so the OP (using 2010) won't be able to open it.
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2013 SP1.1 Update 1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool in Drawing Manager
    BLHDrafting
    01-15-2013 12:41 PM in reply to: sbixler
    Sam and Blair, many thanks.
    Good old CONTOUR FLANGE. Never new it could do that. Touchy in the order or operations and in the skecth geometry (had Bendradius*2 for HEM width but just had too keep trying to get it to work).
    Maybe 1 for the developers but the cut in the FACE side of the part isn't needed for manufacturing this part. This only occurs when you have the CT as an extension to the extents of the FACE. If the FACE includes the length of the HEM then these extra cuts are not generated.
    Brendan Henderson
    Web www.blh.com.au
    Twitter @BLHDrafting
    Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
    ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD
    Inv R2013 PDS SP1.1 Update 2, Vault 2013 Workgroup Update 1
    *Expert Elite*
    01-15-2013 12:51 PM in reply to: BLHDrafting
    Unfortunately the OP had unconstrained sketches in the original post and only visits here about once a year and apparently didn't see the better solution.
    *Pro
    01-16-2013 04:47 AM in reply to: BLHDrafting
    You're right about the unneccessary cut on the face.  This one eliminates that, but I'm not too pleased with the way it opened up the ends of the miters.  Oddly enough, the preview while creating or editing the Contour Flange feature looks much better than the finished product:Sheet Metal Corner 1.PNG
    The only way I found to make it look "right" is to choose Arc Weld for the corner relief shape.
    Sam B
