• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *Expert Elite*
    blair
    Re: shape
    12-12-2012 08:51 AM in reply to: tborland
    Leave it with me for a while, I think that this might have to be converted to a surface model and patches done to get the blend and then back to a solid.
    I tried some delete face and heal, but it's hung up my system.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    Please use plain text.
    Active Contributor
    Re: shape
    12-13-2012 03:56 AM in reply to: blair
    Greetings Blair
    I would truly appreciate the model when you do get a chance.Surfaces is 1 tool i would like to learn
    Best Regards
    Tony
    Active Contributor
    Re: shape
    12-17-2012 03:19 AM in reply to: blair
    Hi
    I attempted to create this shape with surfaces.Having not done before this is as far as i can go at this point...is this how you are going to create the shape with surfaces?
    It would be nice to get this hape correct.
    Thanks again
    Active Contributor
    Re: shape
    12-18-2012 05:16 AM in reply to: blair
    Hi Blair
    Just a quick question
    1. Was the attached surface model how you would make the model?
    2. Will you be able to post your attempt anytime soon
    Thank you
    *Expert Elite*
    blair
    Re: shape
    12-18-2012 08:23 AM in reply to: blair
    I haven't even had time to look at doing anything on this (some of us work 6 days a week and do this to fill in the remainder of the time).
    You should be starting to coil the other way. You will still have a problem with the transition of the "Feed Tube" into the body. Either this needs to have a pitch (increasing in radius) or the center of the "Feed-Tube" can't be at the same point as the center of the body.
    Win7-64
    Active Contributor
    Re: shape
    12-19-2012 04:32 AM in reply to: blair
    Hi Blair
    Yes i appreciate any help you offer.....you guys are generous in devoting your time with help.....i will just keep checking back just in case you may find some time.If not i understand you are too busy
    Best Regards
    TB
    Active Contributor
    Re: shape
    12-20-2012 06:00 AM in reply to: tborland
    Here is the section i am having trouble creating....is this for surfaces to get the correct appearance?
    Active Contributor
    Re: shape
    12-21-2012 05:29 AM in reply to: blair
    I made a little further progress.I would sure like some help with this.If i can get the throat section correct the rest i can finish..I am not familiar with surfaces but i have tried to use for this section but ubfortunately do not know how to get it to look like the picture attach..
    Can someone help with this section so as to create like in the picture
    Thanks alot
    Tony
    Active Contributor
    Re: shape
    12-21-2012 02:37 PM in reply to: blair
    Is there any reason why i cannot get any help on this part (surface part - picture included)...maybe i should just forget asking
    I understand and appreciate any help but i see other post getting help which are no more dificult then this request...if it is not possible to achieve i would rather someone say and i will stop asking
    Merry christmas to you all
    Tony
    *Expert Elite*
    blair
    Re: shape
    12-22-2012 08:07 PM in reply to: tborland
    1.) When people post with files "created with educational version", people are reluctant to do the students work. This shows the tube with the proper transistion/blend into the body.
    Win7-64
