• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    section views in colour
    171 Views, 4 Replies
    05-20-2012 04:58 AM
    I create muliti solid parts.  In the .idw view I want the section views to have same colour as the model.  Is it possible?
    Thanks.
    Please use plain text.
    Product Support
    Dennis.Ossadnik
    Re: section views in colour
    05-23-2012 06:45 AM in reply to: rajeshindi
    Hi rajeshindi,
    i assume, you are faced with a problem like this?
    Section A-A does not honor your color? But you are expecting a result like Section B-B?
    The section view of multi body part does only use the color that is assigned to the solid body. If you only apply your color to the feature (Extursion, ...) it will look like A-A.
    Please go to your part and call the properties of the solid body:
    And apply your color here:
    After that update your drawing and your section view will be as expected.
    Is that the workflow you were looking for?
    If so, please use the button "Accept As Solution".
    Dennis Ossadnik
    Support Specialist
    Product Support
    05-23-2012 08:25 AM in reply to: Dennis.Ossadnik
    Thanks for your reply.  it is useful and appreciated.  Not all the time, it is possible for me to go for shaded view and section it.  It would be very useful if the section view and the base view is shown as per the actual model colour.  Is it possible or some thing for wish list?  ( I am aware of selecting the required lines manually and changing the colour which time consuming)
    Product Support
    Dennis.Ossadnik
    06-12-2012 02:00 AM in reply to: rajeshindi
    Hi rajeshindi,
    sorry, I'm not sure if i catched what you would like to do...
    Which lines do you want to select and change?
    Do you need a view like this (C-C):
    All lines of the body including the hatch have to be in bodies color?
    Please post a screenshot how your expected result would look like.
    Dennis
    Dennis Ossadnik
    Support Specialist
    Product Support
    10-09-2012 10:26 PM in reply to: Dennis.Ossadnik
    Sorry for the late reply.
    Some how I have overlooked this reply.
    Sorry.
    I am looking for view like c-c.
    Thank you.
