• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    section views - background items
    29 Views, 4 Replies
    11-14-2002 04:18 AM
    Is there a way to show only what you cut through in a secion view? In other words, background geometry is not visible. I can turn the individual lines off, but that is very time-consuming.
    thanks,
    Andy
    Please use plain text.
    *G, Ed
    Re: section views - background items
    11-14-2002 04:28 AM in reply to: aritter
    If you right click the section in the tree, click
    show contents You can shut off vissibility to any components you dont want to
    see.
    Is
    thanks,
    Andy
    *Hinterhoeller, Richard
    11-14-2002 04:42 AM in reply to: aritter
    Andy:
    In the parent view, the one from which the section was created, show
    contents and turn off the visibility of the ones you don't want to see.
    Richard
    New Member
    Re:
    11-14-2002 05:06 AM in reply to: aritter
    thanks for the responses.
    Actually, I was concerned with a section view of an individual part. I guess there is no quick way in that scenario.
    Good to know the choices for an assembly, however.
    thanks,
    Andy
    *Maas, Karl
    Re:
    11-18-2002 12:29 AM in reply to: aritter
    Basically it can be done by this long method using
    a series of "extra" views:
    - Create a side view
    - create a section view through a point that
    divides the part with the arrows pointing towards the half of the part that you
    want to use in your final section.
    - create another side view by projecting from the
    first section ( it will only show the half of the part within your section
    definition)
    - lastly, create the section view you want by
    sectioning from this new projection. (since the unwanted stuff is not seen in
    the projection view, it won't show in the new section.)
    K
    thanks
    for the responses.
    Good to
    thanks,
    Andy
