• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    section problems on open shell.
    44 Views, 14 Replies
    11-25-2002 03:03 AM
    I posted in CF, I have an shelled tube open on one end that I drew in IV6 sp1. the other end is thickened and then I gave it a full radius. I cannot get the section lines in the idw to show up right.. any suggestions as to the correct way to draw? anyone else have this problem? I'm using an oxygen VX1, is it graphics related?
    David
    Please use plain text.
    *Gwin, Hal
    Re: section problems on open shell.
    11-25-2002 03:55 AM in reply to: davejan
    How about using a revolve instead of a
    shell?
    Hal Gwin
    Mechanical
    Designer
    Xenogen
    Active Contributor
    Re:
    11-25-2002 04:16 AM in reply to: davejan
    good point, I'll give it a try..
    I wonder why IV couldnt section it? The solid seemed fine. I wonder, does anyone else see the screwed up section lines in my example, like it cannot find the boundry. It might have something to do with sectioning fillets, or my graphics card.
    Thanks, David
    *J, Dave
    Re:
    11-25-2002 04:23 AM in reply to: davejan
    I'm having exactly the same problem with your file.
    I'm using a VX1 Pro also, though.
    good
    David
    *J, Dave
    11-25-2002 04:27 AM in reply to: davejan
    I got your file to work. IV is having a problem
    with your scale. 40x seems a bit much for it for some reason. I scaled it down
    to full size, and hatch works fine. Don't know why. (Bug?!)
    I
    graphics related?
    David
    *Howard, Jeff
    11-25-2002 04:40 AM in reply to: davejan
    The section lines appear to be all right, but the hatch is apparently using
    very course facet lines instead of an arc for the trim border. Scale the
    hatch to .125 and the trim lines are easy to see. This all appears to be
    caused by the large magnification of the drawing view. (Is the part
    representative of something you are doing?) How to fix it; I haven't a clue.
    Perhaps someone else or someone at Adesk can comment.
    Jeff
    "davejan" wrote in message
    news:f127302.-1@WebX.maYIadrTaRb...
    graphics related?
    David
    Active Contributor
    Re:
    11-25-2002 04:46 AM in reply to: davejan
    I tried revolving, the same thing happened. It must have something to do with the scale then. it works fine in both cases at 1:1, but at 40x it screws up. but.. that is the size of the parts we are making, I'd like to keep the ipt at full size not blown up just to make the idw work at 1:1..
    most parts I draw are scaled 20x to 60x in order to see them.
    David
    Active Contributor
    Re:
    11-25-2002 04:51 AM in reply to: davejan
    got it, that makes sense..
    I posted the lase reply as you posted yours. I had said that this is the size of most of the parts that I draw, I hate to have to draw the ipt bigger just to satisfy the idw..
    Active Contributor
    Re:
    11-25-2002 04:52 AM in reply to: davejan
    Oh, and it worked fine in IV 5.3.
    David
    *J, Dave
    Re:
    11-25-2002 05:01 AM in reply to: davejan
    Just out of my own curiosity, I scaled the view to full scale and zoomed in
    really close. I noticed that the hatch lines don't quite match-up to the object
    lines even at full scale. It seems to draw stright border lines, like AutoCAD's
    circles before you regen. the drawing. Seems like a IV problem.
    Dave Jacquemotte
    davej@autoconcorp.com
    "Jeff Howard" wrote in message
    news:55D6DD09E58231BAEAC2838ABF0FFE91@in.WebX.maYIadrTaRb...
    > Jeff
    > graphics related?
    > Thanks,
    > David
