• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    Distinguished Contributor
    Accepted Solution
    scaling
    167 Views, 8 Replies
    06-22-2012 07:03 AM
    Hello everyone, In my journey on learning inventor I ran into this problem. Can I set a drawing scale? If I want to print 1:2,
    2:1 and so on? If so how?
    thanks
    Please use plain text.
    *Expert Elite*
    Cadmanto
    Re: scaling
    06-22-2012 07:55 AM in reply to: drafter1411
    Can you be more specific?  Are you talking about printing or just your on screen drawing view scales?
    The first view placed can have the scale set in the dialog window and that sets the drawing scale.
    Best Regards,
    Scott McFadden
    (Colossians 3:23-25)
    Re: scaling
    06-22-2012 08:05 AM in reply to: drafter1411
    HI and thanks, I want to print at a scale like 1:1 or 2:1. where do I do this?
    *Expert Elite*
    Cadmanto
    Re: scaling
    06-22-2012 08:25 AM in reply to: drafter1411
    You should see something like this in your print manager when you go to print.
    SCALE.JPG  The custom selection will allow you to do the 2/1 and so on.
    Best Regards,
    Scott McFadden
    *Expert Elite*
    blair
    Re: scaling
    06-22-2012 08:27 AM in reply to: drafter1411
    Select the Print button, then select the "Custom" radio button. This will then allow you to set your scale factor in the dialogue box.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 320.18
    SpacePilot Pro 3.16.3 / 6.16.1 / 4.11
    Re: scaling
    06-22-2012 08:46 AM in reply to: drafter1411
    this is what my 2012 shows when I click on print.
    *Expert Elite*
    blair
    Re: scaling
    06-22-2012 08:52 AM in reply to: drafter1411
    Looks like you are on XP, we haven't been on XP for at least four years. This is all I remeber for the last number of versions when hitting the print button from the top of the main header bar.
    Win7-64
    *Expert Elite*
    Curtis_Waguespack
    Re: scaling
    06-22-2012 08:56 AM in reply to: drafter1411
    Hi drafter1411,
    Try it from a drawing as blair shows, and you'll see the options you're looking for. I'm not sure how you'd print to scale from a part model as you show, since the scale/zoom factor is rather unknown.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    *Expert Elite*
    Cadmanto
    Re: scaling
    06-22-2012 09:18 AM in reply to: drafter1411
    If you are running XP, then there most definately could be an incompatibility issue.
    You might want to look into upgrading because MS is stopping their support of XP in 2014
    http://www.microsoft.com/en-us/windows/endofsupport.aspx
    Best Regards,
    Scott McFadden
