Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
reproducib le angle constrain issue inv 2013 pro SP1
- Highlight
- Email to a Friend
- Report Inappropriate Content
I just set up an angle constrain with min and max values (explicit vector) and when I grab and move the part inv will crash, it happened 2 times after restart too...
I have inv2013 Pro with the latest SP1 installed - win7 ultimate
Ric
Re: reproducib le angle constrain issue inv 2013 pro SP1
- Highlight
- Email to a Friend
When using the components to follow your steps, it is not reproducible. Maybe it is related to the dataset you have. So could you attach the dataset or send me @ river-yijiang.cai@autodesk.com? Tha will help us for further investigation.
River Cai
Quality Assurance Team
Autodesk, Inc.
- Highlight
- Email to a Friend
I tried it reproduce according to your description, but I don't have crash on my machine.
Maybe it sounds related to your dataset. So could you attach the dataset for further investigation?
Stanislav
- Highlight
- Email to a Friend
Hi! This might be a known issue with this particular workflow. I need to see the exact dataset to confirm. Does it happen on R2013 also? If yes, more than likely it is the same case.
While the issue is still being investigated, you can try the following to avoid the crash.
1. Try grounding one of the components.
2. Try to reduce degrees of freedom in the assembly.
Thanks!
Principal SQA Engineer, Inventor
Manufacturing Group
Autodesk, Inc.
