Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
rectangle pattern
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Inventor 2013 part file attached.
I am trying to get the rectangle pattern to form 8 blades of the same shape and height across the barrel.A picture shows how the height is lost within the barrel..The only blade which is the same height is the 2 outside blades
Is the rectangle the right tool to produce the result?
Terry
Re: rectangle pattern
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This same question has come up here several times in the past - is it a class assignment?
A search should turn up the solution. As I recall there is a bit of a trick.
Inventor Professional 2014 Edu 64-bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
No it is not a classroom assignment just something i want to learn to do.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
JD,no luck with the search.Do you remeber the trick?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Would anyone know how to create this rectangle pattern please?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have made some progress.Should the blades be equal distances between each other...sketch shows different distances even though the 2 outside blades are same
Terry
