• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Terry__Close
    rectangle pattern
    220 Views, 5 Replies
    12-07-2012 03:48 AM
    Inventor 2013 part file attached.
    I am trying to get the rectangle pattern to form 8 blades of the same shape and height across the barrel.A picture shows how the height is lost within the barrel..The only blade which is the same height is the 2 outside blades
    Is the rectangle the right tool to produce the result?
    Terry
    Please use plain text.
    *Expert Elite*
    Re: rectangle pattern
    12-07-2012 04:19 AM in reply to: Terry__Close
    This same question has come up here several times in the past - is it a class assignment?
    A search should turn up the solution.  As I recall there is a bit of a trick.
    Valued Contributor
    Terry__Close
    12-07-2012 04:38 AM in reply to: Terry__Close
    No it is not a classroom assignment just something i want to learn to do.
    Valued Contributor
    Terry__Close
    12-10-2012 06:02 AM in reply to: Terry__Close
    JD,no luck with the search.Do you remeber the trick?
    Valued Contributor
    Terry__Close
    12-11-2012 03:33 AM in reply to: Terry__Close
    Would anyone know how to create this rectangle pattern please?
    Valued Contributor
    Terry__Close
    12-12-2012 04:47 AM in reply to: Terry__Close
    I have made some progress.Should the blades be equal distances between each other...sketch shows different distances even though the 2 outside blades are same
    Terry
