• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    Distinguished Contributor
    "Edit Hole Note" feature problems
    28 Views, 3 Replies
    11-18-2002 01:11 AM
    This may be flawed in my opinion or I'm not doing something correct. Let's say I have a part file that has a drilled thru hole with a counter bore and is a Metric part. Now in the drawing module I'm using english units with metric as alternate. The problem is that the "edit hole note" feature won't allow for alternate units worse yet it will only use the units that are in the part file. So I'm right back to where I was in release 5.3 (forcing dimensions into the drawing module). Need referential integrity please!
    Please use plain text.
    *Dotson, Sean
    Re: "Edit Hole Note" feature problems
    11-18-2002 02:16 AM in reply to: ohunome
    The hole feature should use the units in which the
    hole was defined regardless of the template units.
    If you are making a manual dim of a hole, make a
    new dimension style and define the units to be mm.  Use this style when
    adding these hole dims...
    Sean Dotson, PE
    href="http://www.sdotson.com">http://www.sdotson.com
    ...sleep is for the
    weak..
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    This
    please!
    Re:
    11-18-2002 02:30 AM in reply to: ohunome
    I can understand having thread holes not allowed to change but a counter bore or drilled hole should have flexibility.
    *McConnell, Cory
    Re:
    11-18-2002 02:58 AM in reply to: ohunome
    I have found them very flexible compared to 5.3.
    Cory McConnell
    BJ pipeline Inspection
    "ohunome" wrote in message
    news:f12469f.1@WebX.maYIadrTaRb...
