• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    propeller
    447 Views, 8 Replies
    12-07-2012 04:12 AM
    Hi all
    How are complex shapes created in Inventor.I have started a propeller but at this point am only able to do the hub.Could a sample be posted in Inventor 2013 on how to create the propeller blades.Is this modelling for this shape done with surface modelling or can it be created with solid modelling technique?
    It would be good if a sample is posted of how you would model the blade as such in the picture
    Best Regards
    Harold
    Inventoir 2013 Education version
    Please use plain text.
    Re: propeller
    12-07-2012 04:22 AM in reply to: harold_kennedy
    This question has been asked here several times in the past.
    If a search doesn't turn up a solution, post back and I'm sure someone will post an example solution.
    Inventor Professional 2014 Edu 64-bit
    Re: propeller
    12-07-2012 04:47 AM in reply to: JDMather
    I did a quick search..not much to go on..hopefully someone will post an example
    Re: propeller
    12-07-2012 07:42 AM in reply to: harold_kennedy
    Check this one first, them I'll find some others
    http://forums.autodesk.com/t5/Autodesk-Inventor/Boat-prop-models/m-p/1533804#M179996
    Oops, never mind - the how to on that one is dead.
    Let me look some more.
    Distinguished Contributor
    Mason-Paul
    Re: propeller
    12-07-2012 09:01 AM in reply to: harold_kennedy
    The attached 4 page PDF, (Version 6 most PFD readers will open this version) file may be of some help, page 4 of this file may give a suggestions as how to proceed by using a series of sketches at the calculated pitch angle and one or more of the profile to form a series of lofts
    Thanks in advance for any help & advice
    Inventor 2012 Pro
    Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
    Valued Mentor
    Re: propeller
    12-11-2012 06:25 AM in reply to: Mason-Paul
    A propeller is just a screw so use the coil tool.
    Draw the cross section
    Use coil to input pitch
    Sketch the projected blade area shape that you want and cut it down to 1 blade
    pattern the blade.
    Not an exact method for production but good enough to make a simple model for visualisation
    Valued Mentor
    mpatchus
    Re: propeller
    12-11-2012 09:11 AM in reply to: Mason-Paul
    I used to use prop data similar to this as an excercise for my advanced students.  It usually gave most of them fits, but occaisionally one would solve it.
    I've included the files (Inventor 2012) if you wish to see how this model was constructued.
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    Re: propeller
    12-11-2012 09:16 AM in reply to: mpatchus
    Harold - are you still working on this?
    I'm sure you can get plenty of help here but you will have to indicated a continued interest in solving the problem.
    Re: propeller
    12-12-2012 04:06 AM in reply to: harold_kennedy
    I am definately still interested.Mike that is a excellent model and JD i would like to learn how to create (even start) on those blades..It will take me a little time but i would like to learn to model like that..
    Cheers
    Harold
