• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Accepted Solution
    pos rep, view rep and ilogic
    313 Views, 3 Replies
    03-15-2012 12:32 AM
    Hi
    Is it in ilogic possible to check which pos rep that is active using a rule? Is it possible to activate a view rep using a rule?
    I'd like to do something like:
    If this "pos rep name" is active, then activate this "view rep name"
    Asle Martin Svastuen
    Autodesk Product Design Suite Ulitmate 2012 Sp1 / Vault Collaboration 2012 Sp1
    HP EliteBook 8560w
    Intel(R)Core(TM) i7 CPU Q 720 @ 2,0GHz 2,0GHz
    16GB RAM
    Windows 7 X64 SP1
    Please use plain text.
    Employee
    Re: pos rep, view rep and ilogic
    03-15-2012 02:01 AM in reply to: amasva
    I did not get the existing function in iLogic, but this can be accomplished via Inventor API -
    Sub Main()
        Dim oDoc As AssemblyDocument
        Set oDoc = ThisApplication.ActiveDocument
        Dim oCompDef As AssemblyComponentDefinition
        Set oCompDef = oDoc.ComponentDefinition
        Dim sActivePR As String
        sActivePV = oCompDef.RepresentationsManager.ActivePositionalRepresentation.Name
        Dim sActiveDV As String
        sActiveDV = oCompDef.RepresentationsManager.ActiveDesignViewRepresentation.Name
        Dim sActiveLOD As String
        sActiveLOD = oCompDef.RepresentationsManager.ActiveLevelOfDetailRepresentation.Name
    End Sub
    And you could also use this code sample in iLogic, and maybe the error shows up, and you could remove the "Set" in code line to fix it.
    River
    River Cai
    Quality Assurance Team
    Autodesk, Inc.
    *Expert Elite*
    Curtis_Waguespack
    03-15-2012 09:27 AM in reply to: amasva
    Hi amasva,
    Here is an example that might help, along with some sample files.
    I hope this helps.
    Curtis
    ' set a reference to the assembly component definintion.
    ' This assumes an assembly document is open.
    Dim oAsmCompDef As AssemblyComponentDefinition
    oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
    'toggle Between Positional Representations
    If oAsmCompDef.RepresentationsManager.ActivePositionalRepresentation.Name = "Master" Then
    oAsmCompDef.RepresentationsManager.PositionalRepresentations.Item("Stacked").activate
    ElseIf oAsmCompDef.RepresentationsManager.ActivePositionalRepresentation.Name = "Stacked" Then
    oAsmCompDef.RepresentationsManager.PositionalRepresentations.Item("Master").activate
    End if
    'set View Representation based on of the active Positional Representation
    oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item("Blue").activate
    oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item("Red").activate
    End if
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    03-15-2012 11:22 PM in reply to: Curtis_Waguespack
    Thank you very much Curtis :smileyhappy:
    HP EliteBook 8560w
    16GB RAM
    Windows 7 X64 SP1
