Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
plastic moulded part
- Highlight
- Email to a Friend
- Report Inappropriate Content
How do I create this plastic moulded part? I need to create a rectangular frame with L shape cross section and then add center round hub and then add ribs.
Re: plastic moulded part
- Highlight
- Email to a Friend
Is this a class assignment?
Sketch
Extrude
Revolve
Rib
Fillet
Feature Pattern
are the tools you will want to become familiar with.
Make a first attempt and attach your file here.
- Highlight
- Email to a Friend
Thanks for the suggestions. I drew a rough sketch for the frame and this where i stuck now. I am not sure how to draw the connecting member from corner to the center and how to create ribs in between them. I tried to use rib feature but it is not working.
attached is the frame.ipt.
Thanks.
- Highlight
- Email to a Friend
First thing I notice is that Sketch1 is not constrained or even dimensioned.
You might start here http://home.pct.edu/~jmather/skillsusa%20universit
while someone takes a longer look.
- Highlight
- Email to a Friend
I just created a rough sketch and did not put any dimensions on it. I read the tutotrial but still having issue with creating ribs and creating a corner connecting members.
- Highlight
- Email to a Friend
You will have to constrain sketches before I can help.
I have always found that is faster to constrain than to not constrain.
In fact, Inventor does most of the work for you on this part.
Unconstrained sketches is why Inventor Fusion should have never seen the light of day.
Look in your corners - do those fillets look right?
I used Shell feature as well to make your part.
Is this a school project?
I could run you through the steps - but don't want to give away the assignment.
- Highlight
- Email to a Friend
No this is not a school project. I just purchased Inventor and trying to learn few things and this part is one of the components of packaging solution and I am trying to do some presentation for this packaging features.
I will constrain the sketches and send it you again.
Thnaks.
- Highlight
- Email to a Friend
It appearsthere should be a bit of draft in the first extrude as well.
