• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *M, Jason
    part to sheetmetal -- need help
    24 Views, 3 Replies
    12-06-2002 03:22 AM
    Hello!
    I have a part that I made by drawing the profile and extruding the
    profile out. I would like to make this into a sheetmetal part so that I
    can get a flat layout, and show where the bend lines are, but when I do
    that, it uses the profile as the face, so instead of having a 10 inch
    wide piece of sheet aluminum that's bent, I end up with a 0.100 inch
    thick profile.
    Can anyone help? I'll put it in CF.
    -Jason
    Please use plain text.
    *Keller, Kent
    Re: part to sheetmetal -- need help
    12-06-2002 03:49 AM in reply to: *M, Jason
    Have you tried preselecting the face before making the flat?
    Kent
    Member of the Autodesk Discussion Forum Moderator Program
    "Jason M" wrote in message
    news:BA10F0D383A46FEC869FF05711ADC8A4@in.WebX.maYIadrTaRb...
    > Hello!
    > thick profile.
    > -Jason
    Active Contributor
    12-06-2002 03:53 AM in reply to: *M, Jason
    Jason, I think this is because by default IV uses the front face unless you tell it otherwise, wheras Autocad defaults to the top face.
    *M, Jason
    Re:
    12-06-2002 03:59 AM in reply to: *M, Jason
    Okay, that did it. Thanks!
    > Kent
    >>Hello!
    >>thick profile.
    >>-Jason
