• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    parameter percision problem
    102 Views, 4 Replies
    03-22-2013 09:06 AM
    I am having a problem that i can only attribute to percision error. In my assembly i have a "Parameter" part that consist of a sketch and a few calculated parameters. I am linking parameters in my main assembly as well as some of its parts to this "Parameter" part. I want to drive the length of one of my parts off of a driven dimension in the parameter part sketch, but it causes my assembly constraints to fail. If i use the measure distance tool with the percision set to all decimals and measure the length from the sketch instead of linking to the driven dimension everything works fine. so my question is this. is there any way to set the percision of the parameter values to the same percision as the measure tool set to all decimals.
    Please use plain text.
    Cadmanto
    Re: parameter percision problem
    03-22-2013 10:22 AM in reply to: moneal0514
    What I would do is in your part and assembly templates go to the tools tab on the ribbon and change the precision here.
    check.PNGIf this solved your issue please mark this posting "Accept as Solution".
    Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
    03-22-2013 10:41 AM in reply to: moneal0514
    i figured it out.
    Cadmanto
    03-22-2013 10:56 AM in reply to: moneal0514
    Can you share what it is you figured out?
    So other in the future will know, thus helping them?
    Best Regards,
    Scott McFadden
    03-22-2013 11:01 AM in reply to: Cadmanto
    My part had a lower percision set in document settings than me parameter part. i fixed my problem by maxing both of them out.
