• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Accepted Solution
    pack and go problem
    251 Views, 2 Replies
    07-22-2011 12:46 PM
    after doing a pack and go, to transfer my project from my old machine to my new machine. it continuously gives me this error message when I open up the file. I have attached a screenshot.
    Please use plain text.
    Valued Mentor
    Re : pack and go problem
    07-22-2011 03:49 PM in reply to: kdlklm
    Hi
    I think your Content Center is not properly maped
    try this
    1-pack and go option  :skip library, checked .click ok let the process run and close
    2-in your old machine go inventor application option, Content Center tab, find the location of the library
    3-copy the folder and transfert it to the new machine in the folder indicated in application option
    other workflow
     you can grab the same folder and paste it in library folder who is set  up in the project option
    good luck
    Yannick Verreault
    Inv. 2012 ultimate
    Inv. 2011 pro sp2
    MS Office 2007
    Win 7 pro, core i7 950, asus P6T WS
    nvidia Gforce GTX 295
    WD caviar black 500Go
    WD caviar black 1To
    New Member
    Re: pack and go problem
    10-09-2012 03:03 AM in reply to: kdlklm
    Hello!
    Another problem with the Pack&Go
    When I Pack and Go some models with parts developed with Frame Generator and I want to make changes with Edit in Frame Generator I cannot find the shapes in the Content Center.
    Thanks in advance.
