• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Re: ordinate dimensions
    03-22-2012 05:01 AM in reply to: sbixler
    Thanks, Sam.  That's what I did.  It works fine.  I'll just have to update our styles.
    Bill Schmid
    Autodesk Product Design Suite Premium 2013
    Autodesk Vault Professional 2013
    Dell Precision T1650
    Windows 7 Professional SP1 64-bit
    Intel E3-1270 V2 3.5GHz / 16G RAM
    Nvidia Quadro 2000, Driver 276.42
    256 GB SSD
    Space Navigator, Driver Version 6.16.1
    Please use plain text.
    Valued Mentor
    Rich.O.3d
    03-22-2012 03:22 PM in reply to: Rich.O.3d
    you might have missed something
    You do not need 2 diffenrent styles to have this behaviour.
    Look at the attachments on my last post...
    both scenarios are using the same dimension style.
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
    03-23-2012 04:35 AM in reply to: Rich.O.3d
    Both your attachments show ordinate dimensions the way I want them.  Neither show regular dimensions the way I want them (text horizontal).  I believe two dimension styles are still required.
    Bill Schmid
    256 GB SSD
    Valued Mentor
    Rich.O.3d
    03-25-2012 03:59 PM in reply to: Rich.O.3d
    hmmmm
    I might have missed something
    I differ to sbixler's wisdom on this one.
    (I usually have ordinates setup as a couple of styles anyway...one for RL's EL's etc -in meters)
    ie RL: 12.660 m TOS_________      etc
    CAD Management 101:
    Member
    GrooveM
    03-19-2013 07:24 AM in reply to: Bill.Schmid
    I know this has been a while but I just started using 2013 a couple of months ago and I have the same situation. I am using a corporate license so the settings are directed. In INV 2009 I was able to simply select the orientation in each of the Default (ANSI) as Horizontal and the Ordinate (ANSI) as Inline. But in 2013 the Default (ANSI) is the only one that affects the text orientation (see attached pics). In Pic 1 the Default (ANSI is set to Horizontal (dims in the right view are correct) while at the same time the Ordinate (ANSI) settings in Pic 2 show that the Orientation for Ordinate text is set to Inline yet they remain in the Horizontal orientation. In pic 3 you'll notice that when I set the orientation in the Default (ANSI) settings the Ordinate Dims change. Is there a patch or fix for this issue? Again I am a little behind the times but it seems like there should be a fix for this issue. Thanks in advance for your help and have a great day.
    *Pro
    03-19-2013 07:38 AM in reply to: GrooveM
    I think the problem is that ordinate dimensions on your system are defaulting to use the Default(ANSI) style.  Edit your active Object Defaults style and set ordinate dimensions to use Ordinate(ANSI) instead of Default(ANSI).
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2013 SP1.1 Update 2
    Windows 7 Enterprise 64-bit, SP1
    HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
    SpaceExplorer/SpaceNavigator NB, driver 3.16.2
    still waiting for a foreshortened radius dimensioning tool in Drawing Manager
    Member
    GrooveM
    03-19-2013 10:10 AM in reply to: sbixler
    That was it. I greatly appreciate your help. Take care.
