• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    open part or assembly from window or browser
    77 Views, 1 Replies
    02-08-2012 10:52 AM
    using IV2012
    within the same project file i have three models. one model i can open parts or assemblies from the browser or right click on the component on the window. the other two models upon the right click or selecting in the browser the open or the edit are not available as an operation. can anyont tell me why
    gschmitz
    T7400-64bit XP
    Xeon 3.2 GHz, 8GB
    1.5GB NVIDIA Quadro FX5600
    Factory Design Suite 2012
    Distinguished Mentor
    Re: open part or assembly from window or browser
    02-09-2012 04:07 AM in reply to: GarySchmitz3154
    Might have something to do with having two copies of Inventor running?  This is definitely not recommended, but I don't know if that has anything to do with your problem or not.  Inventor thinks that opening or editing that component is trouble for some reason (may not be a valid reason, though!).
    If you close out of Inventor (both copies!), then open the assembly again, does it work?  Can other users open and edit as expected?
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2012 SP1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool
