• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    open and update drawing from assembly via iLogic
    155 Views, 1 Replies
    11-12-2012 07:39 AM
    Hi All,
    The right click context menu on the top level assembly (on the model tree in Inventor) has the option of 'Open Drawing'.
    Is there a way to do that via iLogic? Unfortunately I can't figure it out if there is. I would like to open and update the relevant drawing.
    Also have tried it the other way around, that is to run my rues in the assembly from the drawing since the drawing is the parent. But I am not sure how to reference the assembly.
    Any comment would be much apprecated.
    thanks,
    Kris
    Please use plain text.
    Active Contributor
    Re: open and update drawing from assembly via iLogic
    11-19-2012 12:48 AM in reply to: Kris_Inv2013
    Am I in the wrong discussion group? Is there group administrator/moderator/tech supp engineer to look at these questions?
    Many thanks,
    Kris
