• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    nige106
    Accepted Solution
    number of diags in ladder to reference the length
    262 Views, 12 Replies
    03-20-2012 08:18 AM
    I'm not sure how to do this but I have a ladder designed and it can vary in length from 1m to 4m. I'd like the number of diags to change based on the ladder length. The length of the diag should change to make up any differnce, not the gap between them.
    File attached
    Please use plain text.
    Active Contributor
    nige106
    Re: number of diags in ladder to reference the length
    03-20-2012 02:45 PM in reply to: nige106
    Would I need to use iLogic to achieve this?
    Active Contributor
    cadull_rb
    03-20-2012 03:04 PM in reply to: nige106
    See the part attached to my post http://forums.autodesk.com/t5/Autodesk-Inventor/Incomplete-part-update-when-sketch-pattern-count-cha... for parameters that can be used to control the pattern. If you can, only sketch the unique instances and pattern the resulting features.
    Scotty87
    03-20-2012 04:13 PM in reply to: nige106
    You don't need iLogic to achieve this, it can all be done through parameters.
    After modelling the ladder (using a component pattern to specify the amount of diags), give the parameters suitable names (eg. LadderLength, DiagQty, DiagOffset, etc.).
    Then in the equation column for LadderLength, type something like this:
    (DiagQty * DiagOffset) + OffsetFromEnd
    This is assuming the distance between end diags and the end of the ladder are equal; otherwise, just type the required distance in place of OffsetFromEnd.
    Keep in mind with this equation you'll be using the diag quantity to drive the length. It can be done so that the length defines the the diag quantity, but this is a bit easier IMO.
    Hope this helps. (BTW, I haven't check out the attachement so hopefully I understood your question properly!)
    Active Contributor
    nige106
    03-21-2012 04:17 AM in reply to: nige106
    Excellent replies. Just had a look through the .ipt cadull_rb posted in his other thread and I found the item I was missing. I hadn't put ceil before my formula which in my case wasn't recognised when I tried using the parameter in the pattern feature.
    Now works perfectly.
    One other quick question unrelated, I want to draw a box around a view that finishes against my drawing border. Is it a case of freehanding by eye the end of the line or can I project the border onto my sketch?
    Valued Mentor
    stephengibson76
    03-21-2012 05:10 AM in reply to: nige106
    you can place a point that will snap to the origin of the paper, then use the fix cammand to root that point, then dimension from that point based on your border dimensions.
    Stephen Gibson
    Autodesk Product Design Suit 2012
    Win 7 Enterprise 64bit
    Intel core i7 2600K Clocked @ 4.7GHz
    16Gb Ram
    Nvidia GTX 580
    Active Contributor
    nige106
    03-21-2012 06:13 AM in reply to: stephengibson76
    Ahh, thank you, thats worked. The only part I wasn't sure of is where you say use the fix command. I haven't a clue what that is.
    Valued Mentor
    stephengibson76
    03-21-2012 06:48 AM in reply to: nige106
    fix constraint, like a perpendicular or tangent constraint, the one with the padlock icon.  You need to fix this point because although it snaps to the 0,0 its not really attached to anything
    Stephen Gibson
    16Gb Ram
    Nvidia GTX 580
    Scotty87
    03-22-2012 02:07 AM in reply to: nige106
    Just re-read your question (and checked out the attachment), and realised that I misinterpreted it. Anyway, my attachment shows what I was originally trying to say (made a few errors in my original post).
    Active Contributor
    nige106
    03-22-2012 02:47 AM in reply to: nige106
    Thanks to everyone who replied for taking time to do so.:smileyhappy:
