Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
notch beams perpendicu lar to each other
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have a situation where need to frame a W14x30 into a W14x61. When I perform the Notch command, the W14x30 is only partially notched. The W14x61 is taller by .05 in. I tried to notch the W14x30 by ending it at the flange edge of the W14x61. I also tried to notch by ending the W14x30 on the other side of the W14x61, both attempts yielding no results. Any guidance to resolve this is greatly appreciated.
Re: notch beams perpendicu lar to each other
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I think you will need to first increase the length so that they intersect.
Can you attach the assembly here?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Found a solution to my own question: Trim/Extend W14x30 to the face of W14x61, then Notch.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I might add, from experience, anytime you are doing a notch function that also requires a trim... do the trim first, so that the G_L cut length will be correct. We've found (at least in 2011) that if you notch first and then trim, the length value does not update.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
*face of the W14x61 web
