Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
multiple extrusions from one draw plane?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That is to say, more than one closed shape on the same plane.
Is it possible? If so, how?
Thanks much in advance
Joe
Re: multiple extrusions from one draw plane?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Do you mean multiple extrusions from one sketch? This is certainly possible. After your first extrusion, right-click on the sketch and select Share Sketch. This makes it available to be used by further features.
If you just mean multiple extrusions from one work plane, then there is no limitation on the number of features that can reference a work plane.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If you can't figure it out - attach your file here.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
works like a dream - awesome! Probably my biggest peeve since I started.
Only thing, option is not available in some cases. Why is that?
Thanks again
Joe
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
donovandigital wrote:Only thing, option is not available in some cases. Why is that?
Attach file here that exhibits this behavior.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Not sure how well that will work - it depends on which level of the hierarchy is active. Not a major deal, as I can just click around until the right object is active.
Just curious - what is the logic behind this "consumed" sketch business? Surely autodesk don't think that most people will only have one extrusion/revolution per plane?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I don't follow the logic of your statement. Attach example file here.
Are you really referring to sketches?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
according to http://wikihelp.autodesk.com/Inventor/enu/2012/Hel
"For parts, surface features and work features are automatically consumed by default to communicate feature dependencies." - What do they mean, feature dependencies? Most of the time, I want to draw separate features on the same sketch. Why is it that by default they are consumed?
I can post if you really want, how would you like me to package? Zip?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Go through this paper
http://home.pct.edu/~jmather/skillsusa%20universit
go through this tutorial (the sketches are already done (see attached) - you might start a new part file and see if you can create them from scratch
http://home.pct.edu/~jmather/content/DSG322/Invent
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
oops, here is the file attachment.
